Is it possible to hide the printing icon on Smart Client's setting menu of the tool bar ?
Hi,
Is it possible to hide the printing icon?
I guess it may be displayed automatically.
In your ViewItemUserControl or ViewItemWpfUserControl add
public override bool ShowToolbar
    get { return false; }
This will disable the toolbar fully.
If you want a toolbar you cannot remove the Print icon and functionality from it.
Hi Bo,
Thank you for your reply.
Sorry for my lack of explanation.
I want to use the toolbar because I need to show other icons.​
Can we remove only Print icon ?
No, If you want a toolbar you cannot remove the Print icon from it.
This is not correct, see Ben’s comment below!
Thank you Bo.
This is the answer we wanted to know.​
Looks like this answer is outdated, now you can add:
public override bool IsPrintEnabled => false;
to your ViewItemPlugin class, and the Print button won’t be added to the toolbar. You’ll still be able to call Print(…) from your plugin if you need to.
